MAXTRAX MKII Black Recovery Boards - Overland Bound
Regular price$ 259.99
MAXTRAX MKII Stealth Black is our most-discrete color, blending in seamlessly with roof racks, bed racks, and it's perfect for scenarios in which you do not want to draw attention to the accessories on your vehicle. We strongly recommend the use of our included Telltale Leashes when using them in the mud!
The SAFE, SIMPLE, QUICK and EASY vehicle recovery device. Simply put, MAXTRAX is the best vehicle recovery board on the market — and the original! Simply place underneath your tires and idle out of the situation you’re stuck in, no matter if it’s SAND, SNOW or MUD!
Whether you’re retrieving your boat from the water, or your 4WD vehicle out of boggy mud, sand or snow, MAXTRAX is the vehicle extraction tool that can make vehicle recovery quicker and easier.
Dimensions:
45” long X 13” wide X 3.5” tall
1150mm long X 330mm wide x 85mm tall
Weight:
8 lbs per individual MKII // 16 lbs per set of MKII
SOLD IN A PAIR
