Storage
Once primed, keep the membranes of the filter hydrated by storing at least 1 inch/2.5 cm of water in the LifeSaver product at all times. Remove and discard the activated carbon filter from the Jerrycan and clean the Jerrycan. Keep the product sealed with the pump and tap in place and do not allow the membranes to dry out. Release pressure before storage by unscrewing the pump slowly until you hear a hissing sound. Storage temperatures should stay within 1°C/14°F and 50°C/122°F.
We recommend storing dirty water, either in the Jerrycan or in other storage containers, and filtering through the Jerrycan as and when clean water is required, to prevent recontamination of previously filtered water.
LifeSaver activated carbon filters come with a shelf life for up to 3 years. We recommend storing them in the packaging they arrived in or use an airtight container or plastic bag (dependent on the quality of the container/bag being fully airtight). LifeSaver activated carbon filters sealed in their aluminium barrier foil have a shelf life of 10 years from the date of sale.
LifeSaver Filters have a minimum 3 year guarantee from the point the customer purchases it from an approved retailer or channel partner, not from the date of manufacturer. In good storage conditions (out of direct sunlight and extremes of humidity and temperature) and in the original packaging the product shelf life can be extended beyond 5 years. LifeSaver Filters sealed in their aluminium barrier foil have a shelf life of 10 years from the date of sale. Unused, the minimum storage temperature is -10°C/14°F and the maximum storage temperature is 50°C/122°F.
Transporting
If you will be flying with your LifeSaver, first release the pressure from the LifeSaver product. Unscrew the pump slowly until you hear a hissing sound. Hold on to the pump firmly whilst unscrewing. Drain off any water and re-seal ensuring the pump is screwed back in place. Pack securely in the hold or within hand luggage to protect the product from impact. Pour 1 inch/2.5cm of water into the vessel when arrived at your destination.
