Prepared for anything and everything.
The Patron is a robust and heavy-duty field knife designed for use in the harshest conditions. There is nothing subtle about the Patron; its weight and balance makes easy work of any outdoors task at hand. If you are searching for the perfect knife to round out your preparation kit, this is your solution.
Specs:
Total Length | 8.8 inch
Blade Length | 4.3 inch
Weight | 6.1 oz
Blade thickness | .18”
Blade | Böhler N690. 57-59 HRC
Handle | G10
Each knife comes with the following items:
Kydex ® sheath
Tek-LokTM belt clip (USA MADE)
- Paracord
About Mikov: Mikov builds on the centuries-old tradition of manufacturing small industrial goods and knives in the "Czech Switzerland", specifically the area of Mikulášovice and Lipová. The first factory, which is a direct predecessor of today's factory, was founded in 1794 by Ignaz Rösler, a merchant in Mikulášovice. Today, Mikov is the largest manufacturer of knives in the Czech Republic.
