One of the most versatile and simple pieces of camp cooking gear we've used. And it takes almost no room in your pack out!
Two Parts. That's It.
Unlike other portable grills, Grill M1 Edition is a two part assembly: a frame that you spread open and a cooking surface that you unroll and secure in place. Want to adjust the height of your grill? No problem, just move the stainless steel stoppers to your desired height mode.
Compact Form.
Smaller in diameter than most water bottles and weighing approximately 1 kg (2.2 lb), Grill M1 Edition is designed for everyday use. When you’re ready to transport it, simply fold the frame, roll our cooking surface into it then zip it away into our included premium carrying case.
Premium Materials.
Every component of the Grill — from the frame legs to the bolts and screws — is made out of 304 stainless steel, ensuring that you don’t need to worry about the low melting point of aluminum or the low stability temperatures of non-stick coatings. The frame, rods, and technical stainless steel aircraft cable makes for a sturdy, corrosion-resistant experience that won’t have you wondering whether or not it can support you on your journey.
