Luci Solar String Lights + Detachable Power Hub: White 44&
Luci Solar String Lights + Detachable Power Hub: White 44'
Regular price$ 69.95
Powerful and expansive, Luci Solar String Lights + Power Hub provides up to 40 hours of energy-efficient light on a single charge. Featuring a 44 ft nylon-braided cord, 20 shatterproof bulbs, and 40 warm white LEDs, and a detachable 4,000 mAh rechargeable battery with mobile charging capabilities, these solar string lights provide illumination and ambiance to any outdoor space.
With the completely detachable unit, you can remove and recharge the unit via the solar panel or built-in USB port, all while leaving your string setup intact. These weather-resistant string lights are the ultimate in overhead lighting. So whether it’s a backyard, an RV, or a cozy campsite, Luci Solar String Lights 44' turns any outdoor space into a welcoming one.
• 44 ft nylon-braided cord in expandable unit
• Detachable 4,000 mAh rechargeable battery with mobile charging capabilities
• Up to 140 lumens
• 40 warm white LEDs in 20 shatterproof bulbs
• Lasts up to 40 hours on a single charge (see details under "tech specs" below)
• Recharge via solar panel or quick charge via USB
Product features
• Expandable and detachable design
• 40 warm white LEDs in 20 nodes
• Silicone-coated 4 feet on base for stability
• Adjustable TPU handle
• Built-in USB ports
• Water resistant: IPX4
• Operating temp: 32°F - 113°F (0°C - 45°C)
• 1 year manufacturer’s warranty
Product functions
• Unit can be detached from string
• 3 modes: Low (20 lumens, up to 40 hours), medium (70 lumens up to 24 hours), high (140 lumens up to 8 hours)
• Shines up to 140 lumens
• 2 second quick shut off
• Battery level indicator
Charge
• Recharge via solar or quick-charge USB (3-5 hours)
• Rechargeable 4,000 mAh Li-ion battery
• Monocrystalline solar panel
Dimensions
• Diameter: 7 inches (17.8 cm)
• Height: 2.87 inches (7.3 cm) when closed
• Weight: 745g (Not including USB cable)
