BOREAL21 BLADES
BOREAL21 BLADES
BOREAL21 BLADES
BOREAL21 BLADES
Regular price$ 10.00
Blade Type
*FOR THE BOREAL21*
Customize your BOREAL21 with the blade that works best for your type of outdoor exploration.
ALL PURPOSE BLADE
This medium toothed blade has a double pointed raker between sets of cutting teeth, which clears the cutting notch of wood chips and fiber. This popular style cuts green wood but is right at home cutting dry hard and soft woods. Rust protective coating and hardened points make this versatile blade perfect for most uses. Push/pull cutting action.
AGGRESSIVE SIDNEY RANCHER II BLADE
The Sidney Rancher II is custom designed and favored by those seeking an extremely aggressive and long lasting blade. Long sharp edges in a unique pattern of large teeth provide aggressive cutting. This heavy gauge blade will plow through
wood.
HUNTERS BLADE
The Hunter Blade is ideal for cutting through bone or meats. The serrated high quality stainless steel blade stands up to the elements and is easy to clean. This blade is the perfect choice for field dressing of game. Push cutting action.
