BOREAL24 BLADES
BOREAL24 BLADES
BOREAL24 BLADES
Regular price$ 12.00
Blade Type
*FOR THE BOREAL24*
Customize your BOREAL24 with the blade that works best for your type of outdoor exploration.
ALL PURPOSE BLADE
This medium toothed blade has a double pointed raker between sets of cutting teeth, which clears the cutting notch of wood chips and fiber. This popular style cuts green wood but is right at home cutting dry hard and soft woods. Rust protective coating and hardened points make this versatile blade perfect for most uses. Push/pull cutting action.
AGGRESSIVE SIDNEY RANCHER II BLADE
The Sidney Rancher II is custom designed and favored by those seeking an extremely aggressive and long lasting blade. Long sharp edges in a unique pattern of large teeth provide aggressive cutting. This heavy gauge blade will plow through
wood.
