iOnBoost™ V8 TORQUE
iOnBoost™ V8 TORQUE
iOnBoost™ V8 TORQUE
iOnBoost™ V8 TORQUE
iOnBoost™ V8 TORQUE
iOnBoost™ V8 TORQUE
iOnBoost™ V8 TORQUE
iOnBoost™ V8 TORQUE
iOnBoost™ V8 TORQUE
Regular price $ 119.95 Sale price$ 89.90
Put this on your overland gear checklist.
Works best up to 6.0L V8 or 4.5L Diesel engines
TORQUE is defined as “the twisting force applied to an object to cause rotation” – the Wagan iOnBoost V8 TORQUE provides you with 800 peak amps of power to get your engine started, and puts more power at your fingertips without having a bulky device to lug around.
The powerful and reliable 4S Lithium ion battery is able to charge your electronics with QC 3.0 and 2A USB Power Ports.
Worried about safety? Over-charge, over-Voltage, reverse polarity, and anti-sparking (short circuit) protections are all built in to the iOnBoost V8 TORQUE to make sure that you are able to use the device safely - even if you’re not mechanically inclined. If you connect the SMART Cables to the battery incorrectly, a red light and audible tone alert you of the condition and won’t let electricity flow. When correctly connected, they illuminate green - showing that they are ready to use.
And another safety consideration is that you and your loved ones won't be stranded in the middle of nowhere unable to get back to civilization.
Quick List of Features
  • 800A Peak Jump Starter
  • Up to 6.0L V8 or 4.5L Diesel
  • 2 USB Power Ports
  • LED Flashlight
  • SMART Cables
  • QC 3.0 Charging
  • Storage Case Included
  • Certifications: CE, RoHS, FCC
As Seen in the Media
