iOnBoost Slim
Not your average battery power bank, the iOnBoost Slim is 5400mAh (20.0Wh) of power at your fingertips. Recharge your phone or tablet, power your USB devices, find your way in the dark, and jump start your car; all with this palm-sized device!
You can never have too many power options.
Battery Power Bank
Utilizing a powerful LiPo (Lithium-ion Polymer) battery, the iOnBoost Slim provides enough power to recharge most smartphones 2x or more!
Jump Starter
With the included Smart Cables, the iOnBoost Slim can jump start vehicles with up to V6 engines; this includes cars, small trucks, motorcycles, scooters, and more.
Easy Recharge
The iOnBoost Slim only requires a USB port to recharge. Simply plug-in any micro-USB cable, and the iOnBoost Slim will begin to charge; charging will end when the iOnBoost Slim is full.
Compact Size
Smaller than most smartphones, the iOnBoost Slim easily fits in your back pocket. Take it with you anywhere you go and be certain that you have the power you need wherever you go.
Safe to Use
The iOnBoost Slim features Over-charge, Over-discharge, Reverse Polarity, Short-Circuit, and Over-voltage protections built-in. Using the iOnBoost Slim is completely fool-proof and safe for nearly anyone to use.
Smart Jumper Cables
Our Smart Jumper cables make jump starting your vehicle safe and worry free. The Smart cables and the iOnBoost Slim are protected if you accidentally place the jumper cables on the wrong battery pole.
Quick List of Features
- 5400mAh LiPo Battery Bank
- 2A USB Power Port
- Jump Starter (up to V6 engines)
- Bright LED Flashlight
- Recharges via micro-USB
- Compact Size
- Accessories Included
