Utility & Field Bag
Utility & Field Bag
Utility & Field Bag
Utility & Field Bag
Utility & Field Bag
Utility & Field Bag
Regular price$ 139.00
Color
 Axe Not Included
The Utility & Field Bag was developed as a way to keep your axe secure and other maintenance items organized and at the ready. Easily add work gloves, flashlight, jumper cables, and any other vehicle mainstays to keep them from sliding around in the back of your truck.
The offset handle design allows for a balanced carry and if you need both hands, the straps pull double duty and the bag can be worn as a pack. The included blaze orange utility mat keeps loose items visible in the field or your backside dry while investigating under your rig.
FEATURES
  • 14oz. Martexin® Original Waxed Cotton Exterior Provides Superior Water Repellency
  • Rigid Plastic Bottom Increases Stability & Creates A Durable Barrier For Your Tools
  • Off-Set Handles Evenly Distribute Weight For A Balanced Carry
  • Handles Pull Double Duty As Back Pack Straps For Hands-Free Carry
  • 420D Double Sided Blaze Orange Utility Mat (24”x36”) Provides A High Visibility Surface For Items That You Don’t Want To Lose In The Field
  • Hook & Loop Closure Allows For Easy Size Adjustment & Secures Up To A 26” Axe
  • 500D Cordura® Nylon Liner Is Durable and Field-Tested
  • Leather Pull Tabs on Zippers Allow For Ease Of Entry & Closure
SPECS - 26” L x 7.25” W x 4” H | 14 oz.
