Dual Grit Sharpening Stone
Regular price$ 29.00
For Use On All Edged Tools
The 220/400 Field Sharpening Stone was purpose built to leave a fine finish in a small footprint. Each stone is made from Aluminium Oxide, which allows the stone to cut fast and does not require oil to be added to the sharpening process. The 240 grit rapidly removes scratches rolls and blunting, while the 400 grit brings the blade back to a razor's edge.
Please Note : Some natural variation in color may occur. This will not affect the performance of the stone.
Features
  • For Use On All Edged Tools
  • Portable For Field Use
  • Sapphire Ceramic Blend
  • Oil is not required. Water is recommended
  • American Made
Specs
  • Weight | 7.0 oz.
  • Dimensions | 6” x 1 and ⅝” x ⅝”
  • Stone Shape | Rectangle
  • Material | Aluminum Oxide
  • Bond | Hard to Medium Hard
  • Grit | 240/400
