Dual Grit Sharpening Puck & Utility Pouch
Regular price$ 49.00
Grit Level
Color
A Field Kit for Sharpening & Maintaining Edged Tools
Each stone puck is made from Aluminium Oxide, which allows the stone to cut fast and does not require oil to be added to the sharpening process.
Which grit is right for you?
240/400 - The 240 grit rapidly removes scratches rolls and blunting, while the 400 grit brings the blade back to a razor's edge.
220/400 - The 220 grit removes steel in a controlled manner for repairing small chips and minor blade damage, while the 400 side refines the blade for additional sharpening, or restoring a dull blade to a razor's edge.
80/220 - The 80 grit removes steel in a controlled manner for repairing chips and re-shaping blades from heavy use, while the 220 side refines the blade for additional sharpening, or keeping the edge maintained. It’s the perfect combination for repairing your blade by hand, without having to worry about damaging the steel’s temper on a bench grinder or other automatic sharpening device.
Included with each sharpening stone is an American made EDPM (Ethylene Propylene Diene Monomer) rubber band, which provides additional grip when manipulating the stone.  The band is removable and can be used for a variety of outdoor or everyday carry applications.  While gloves are highly recommended, the recessed finger grooves and band combination will keep your hand positioned well above the cutting plane for a secure grip throughout the sharpening process.
Please Note: Each stone is set and cut by hand. Some variation in size and color may occur. This will not affect the performance of the stone.
Features
  • For Use On All Edged Tools
  • Portable For Field Use
  • Sapphire Ceramic Blend
  • Removable EDPM Rubber Band Provides Additional Grip And Secure Loose Items In A Pinch
  • Oil is not required. Water is recommended.
  • American Made with American Materials
Specs
  • Weight | 7.8 oz.
  • Diameter | 3”
  • Stone Shape | Round
  • Material | Aluminum Oxide
  • Bond | Hard to Medium Hard
  • Grit | 240/400
Utilizing a split pocket design, the pouch is purpose built to hold one or more round sharpening stones, or a variety of other maintenance items.  If you don’t need the pouch to keep your stone at the ready, you can easily convert it to organize small electronics or other everyday carry items. Each pouch is hand crafted in the U.S.A using 18oz duck canvas, durable YKK zippers and a leather pull tab.
Pouch Specs
  • Material | 18oz. Duck Canvas
  • Dimensions | 9.5” x 6”
  • Number of Pockets | 2
Please Note: Each pouch ships with one sharpening stone only.
