Zarges Storage Solutions K470 L
Regular price$ 412.00
Add Member Customization?
Add Locks
SUPERIOR PROTECTION TO LAST FOR DECADES
Whatever you have that's heavy duty, the K470 L has you covered. The K470 L is big enough to pack a small burner, JetBoil and kitchen gear and strong enough to use it as a surface to prep your meal on. It will handle whatever you pile into it with ease.
Dimensions: 22.95×15.28×13.26in
Internal Dimensions: 21.65x13.78x12.2in
Weight:  11lbs
The ZARGES K470 aluminum shipping and storage case provides perfect protection, even under the most extreme conditions. The K470 is ATA 300 approved, lightweight, rugged, and dust and water resistant. Its durable construction provides optimal protection for any contents.
This item is excluded from promotional discounts.
Note: Customized Cases are not eligible for refunds or returns.
