A campfire experience like no other. (Seriously.)
“The Original Fire Reflector” by MC Ranch Overland was designed to enhance and improve on all aspects of the campfire and the outdoor cooking experience. Using the principles of a parabolic arc and the properties of aluminum, the Fire Reflector reflects heat exponentially back to users keeping them warm and cozy. It also reflects light into your campsite creating a bright, engaging and warming glow.
The Fire Reflector also creates a controlled cooking environment by managing wind and air flow to maximize your fuel resources and not allow them to burn uncontrollably in the wind.
The strong and lightweight aluminum construction weighs in at 27 lbs and folds neatly into its 1000 Cordura military grade carrying case. (Desert Tan on the outside and reflective orange on the inside.)
Each one of the Fire Reflectors and carrying cases are custom made in Canada. The reflectors are CNC machined with water jet, then hand finished and assembled. The robust carrying cases are also handmade.
The reflector is designed to last a lifetime acting as the arena or theater for sharing stories, making memories and enhancing our collective community… One campfire at a time.
This item is excluded from promotional discounts.
Patent pending.
Weight: 27 lbs
Dimensions: 24 × 1 × 24 in
Set-Up Time: 15 Seconds
Cool Down Time: 90 Seconds
