Description
TORQUE is defined as “the twisting force applied to an object to cause rotation” – our iOnBoost V10 TORQUE provides you with 1000 peak amps of power to get your engine started! Rated for use on all engines up to V10 gas engines and 6.7L Diesels alike!
Why Choose the iOnBoost V10 TORQUE?
Simply put, our 4 cell (4S) battery provides more power than the competitor’s 3 cell (3S) battery. For you that means more power at your fingertips without having a bulky device to lug around.
Features
The 4S Lithium ion battery is able to charge your electronics with QC 3.0 and 2A USB Power Ports.
With the included 12V DC Socket, you can charge and power other devices such as: Smartphone, Walkie-Talkie, Ham Radio, Fan, Lights, and more.
Safety First
Our entire iOnBoost line has undergone extensive safety testing and has several safety features built-in to ensure your safety and the safety of your loved ones.
Over-charge, Over-Voltage, reverse polarity, and anti-sparking (short circuit) protections are all built in to the iOnBoost V10 TORQUE to make sure that you are able to use the device safely - even if you’re not mechanically inclined. And, it's UL Listed!
Safety and Security for Loved Ones
Don’t leave your loved ones vulnerable in a dark parking lot waiting for help. With the iOnBoost V10 TORQUE, they can arrive at their destination safely without ever having to wait for a tow truck or flag down a stranger for a jump start.
SMART Jumper Cables
Remember earlier how I said that you do not have to be mechanically inclined to use the iOnBoost V10 TORQUE? It’s true! Our SMART Cables are nearly fool-proof.
If you connect the SMART Cables to the battery incorrectly, a red light and audible tone alert you of the condition and won’t let electricity flow. When correctly connected, they illuminate green - showing that they are ready to use!
Quick List of Features:
- 1000A Peak Jump Starter
- Up to 7.8L V10 or 6.7L Diesel
- 2 USB Power Ports
- 12V DC Socket
- LED Flashlight
- SMART Cables
- QC 3.0 Charging
- Storage Case Included
- Certifications: UL, CE, TÜV, RoHS, FCC
WARNING: This product can expose you to chemicals including DEHP, which is known to the State of California to cause cancer and birth defects or other reproductive harm. For more information, go to www.P65Warnings.ca.gov.
Specs
- Battery type: Lithium-ion (LiCo02)
- Battery Configuration: (4S) 14.8V
- Battery Watt-hours: 45.0Wh
- Peak amps: 1000A
- Cranking amps 500A
- Capability: up to 7.8L V10 or 6.7L Diesel
- Jumper cables: 10 AWG, SMART, 14"
- DC Accessory Outlet 1: 12V - 5A
- USB power ports: 2
- USB power port: QC3.0 and 5 V, 2.0A
- LED Light Modes: Solid On, flashing, S.O.S.
- Built-in Safety: Protection against over-voltage, over-charge, short circuit, and reverse polarity
- Battery status indicator: 5 bar, LED
- Operating temperatures: 32°F–104°F
- Storage temperatures: -4°F–158°F
- Charging Input: USB-C
- Charging Input Current: 5V, 2A
- Dimensions (LxWxH): 7.0 x 1.2 x 3.2 (inches)
- Weight: 5 lbs.
What's Included:
- iOnBoost V10 TORQUE
- Smart Jumper Cables
- Manual
- Storage Case
- 12V DC Socket
- USB-C Charging cable
Warranty: 1 year
UL Certification: CU72212592 0001
Videos
