Description
The ultra-compact lithium jump starter, power bank, and LED light.iOnBoost V8 TORQUE
TORQUE is defined as “the twisting force applied to an object to cause rotation” – our iOnBoost V8 TORQUE provides you with 800 peak amps of power to get your engine started!
Why Choose the iOnBoost V8 TORQUE?
Simply put, our 4 cell (4S) battery provides more power than the competitor’s 3 cell (3S) battery. For you that means more power at your fingertips without having a bulky device to lug around.
Features
The powerful and reliable 4S Lithium ion battery is able to charge your electronics with QC 3.0 and 2A USB Power Ports.
Safety First
Our entire iOnBoost line has undergone extensive safety testing and has several safety features built-in to ensure your safety and the safety of your loved ones.
Over-charge, Over-Voltage, reverse polarity, and anti-sparking (short circuit) protections are all built in to the iOnBoost V8 TORQUE to make sure that you are able to use the device safely - even if you’re not mechanically inclined.
Safety and Security for Loved Ones
Don’t leave your loved ones vulnerable in a dark parking lot waiting for help. With the iOnBoost V8 TORQUE, they can arrive at their destination safely without ever having to wait for a tow truck or flag down a stranger for a jump start.
SMART Jumper Cables
Remember earlier how I said that you do not have to be mechanically inclined to use the iOnBoost V8 TORQUE? It’s true! Our SMART Cables are nearly fool-proof.
If you connect the SMART Cables to the battery incorrectly, a red light and audible tone alert you of the condition and won’t let electricity flow. When correctly connected, they illuminate green - showing that they are ready to use!
Quick List of Features
- 800A Peak Jump Starter
- Up to 6.0L V8 or 4.5L Diesel
- 2 USB Power Ports
- LED Flashlight
- SMART Cables
- QC 3.0 Charging
- Storage Case Included
- Certifications: CE, RoHS, FCC
WARNING: This product can expose you to chemicals including DEHP, which is known to the State of California to cause cancer and birth defects or other reproductive harm. For more information, go to www.P65Warnings.ca.gov.
Specs
- Battery type: Lithium-ion (LiCo02)
- Battery Configuration: (4S) 14.8V
- Battery Watt-hours: 31.0Wh
- Peak amps: 800A
- Cranking amps 400A
- Capability: up to 6.0L V8 or 4.5L Diesel
- Jumper cables: 10 AWG, SMART, 14"
- USB power ports: 2
- USB power port: QC3.0 and 5 V, 2.0A
- LED Light Modes: Solid On, flashing
- Built-in Safety: Protection against over-voltage, over-charge, short circuit, and reverse polarity
- Battery status indicator: 5 bar, LED
- Operating temperatures: 32°F–104°F
- Storage temperatures: -4°F–158°F
- Charging Input: USB-C
- Charging Input Current: 5V, 2A
- Dimensions (LxWxH): 5.7 x 1.3 x 3.0 (inches)
- Weight: 4.5 lbs.
- MPN: 7505
What's Included:
- iOnBoost V8 TORQUE
- Smart Jumper Cables
- Manual
- Storage Case
- USB-C Charging cable
Warranty: 1 year
Videos
