Power where you want to be.
Uncompromising Quality
The Lithium Cube is a culmination of 30 years worth of power supply knowledge with cues taken from our popular jump-starter, power inverter, and Solar Cube lines. That knowledge cultivated the perfect lithium power supply; one that was full-featured with a solid build quality, could be used anywhere, and is reliable as all can be.
Simplicity
We designed the Lithium Cube to be user friendly and accessible to everyone, everywhere. No proprietary plugs, no special connectors, no hassle finding compatible accessories; our Lithium Cube will work with the set-up you already have and with readily-available components.
Powerful
The Lithium Cube 325 is small, but you can't call it a slouch; with a 300W PSW inverter paired with the 324Wh lithium-ion battery, you'll have what you need to power through your day. Whether you need to power a battery charger, CPAP, laptop, or whatever, we have you covered!
Pass-through Charging
One gripe that we've seen with other units is that they cannot be used while charging; not so with the Lithium Cube! You can charge the Lithium Cube and use it at the same time... how cool is that?!
Full Featured Color Digital Display
Take the guess-work out of using our Lithium Cube! Our Full Featured Display will let you know what is happening at a glance.
- Battery Percentage Remaining
- Power Status
- Battery Hours Remaining (until charged/until discharged)
- Wattage (input/output current)
- Fan On
- Error Detection
Run-Times
One of the most important questions regarding a power supply is, "How long can it power my device for?". We've compiled a clear list of common appliances that you'd power using our Lithium Cube.
How to Use
1) Press the power switch to turn on the power port you want to use (AC, DC, USB); once on, the power icon will illuminate.
2) Plug in your device, That's it!
When you're done, simply unplug your device, press the power switch, and the Lithium Cube will automatically power off after 1-minute.
Built with you in mind
As an American company, we produce products that our families are proud to use. We live and breathe the outdoors; we're out there camping, overlanding, exploring, and knee-deep within the outdoor communities. With that said, it's imperative that our products are safe, reliable, and built to perform.
Like you, we wouldn't want our families using something that doesn't meet our high standards. Our Lithium Cube was built for real-world use with you in mind.
Quick List of Features:
- 120V AC, 12V DC, USB Power Outputs
- Pure Sine Wave (PSW) Inverter
- Recharge via: Solar (MPPT), DC & AC
- Bright Full-Featured Digital Color Display
- Only 7 lbs.! Lightweight, Portable
