Store/Trusted Gear/MAXTRAX MKII Titanium Grey Recovery Boards
SaleMAXTRAX MKII Titanium Grey Recovery Boards - Overland Bound
Trusted Gear
$ 279.99
Members save on merch. Sign in to see member pricing.
Join
Easy returnsSecure checkout
Goes well with any build, MAXTRAX MKII Titanium Grey are fairly easy to see in the muck, however we do recommend using the included leashes for increased visibility.
The SAFE, SIMPLE, QUICK and EASY vehicle recovery device. Simply put, MAXTRAX is the best vehicle recovery board on the market — and the original! Simply place underneath your tires and idle out of the situation you’re stuck in, no matter if it’s SAND, SNOW or MUD!
Whether you’re retrieving your boat from the water, or your 4WD vehicle out of boggy mud, sand or snow, MAXTRAX is the vehicle extraction tool that can make vehicle recovery quicker and easier.
Dimensions:
45” long X 13” wide X 3.5” tall
1150mm long X 330mm wide x 85mm tall
Weight:
8 lbs per individual MKII // 16 lbs per set of MKII
SOLD IN A PAIR
Returns and Exchanges
Damaged or wrong item on arrival gets made right. Contact the support desk with the order number.
Secure Checkout
Card, wallet and Shop Pay are handled by Shopify providing automatic 256-bit SSL encryption, and 3D Secure authentication.
Overland Bound Membership
Join the crew
Access all the features and benefits of Overland Bound with an annual membership and make it official by grabbing your emblem kit.
Membership renews annually. Emblem numbers are assigned at checkout and cannot be transferred.
